I can carve a pattern on easel pro and after try to use a a project from inventables and move and I loose internet connection . Sometimes takes hours to reconnect. Or try to open new in projects and same issues. Seems only with easel.
Your loosing internet connection shouldn’t have anything to do with the CNC or Easel.
Is it possible that your router is plugged into the same power source as the CNC and the router itself it tripping off maybe?
Easel doesn’t actually use the internet when controlling the CNC. That Said, if you like you can try out OpenBuilds Control. I use this program to control my CNC, i download the gcode file from Easel and then open it in Open/Builds and send it to the cnc, I like the layout better and there’s more functionality…
