I have an electronics company and I’m looking for a way to do some aluminum enclosures for prototypes for cheap. I’m ok with it taking a long time to run so long as I know the machine will handle it. My tolerance are not very tight. We’ll just drop a PCBA in there and epoxy it closed.
Is the X-Carve something that will work for this application? Here’s an example enclosure.Enclosure.PDF (77.9 KB)
I thought Inventables just dropped all but the 1000 mm version?
@JaredTabb: The X-Carve could do what you’re wanting, but it’d be pretty slow going. I usually keep my depth per pass around 0.005" for aluminum, so milling out 15 mm over a roughly 3" x 6" are would take… …awhile… You’d also be eating brushes up pretty quickly at that rate.
I’d recommend looking for a more purpose-built machine. Something smaller and more rigid, as @NeilFerreri1 mentioned, would definitely give you better results.
