Today i’ll explain how to use maxscript to transfer any 3D model to generate GCode out of it.
Gethub Source Files: GitHub - HMI1973/Shapeoko-3d-max-script: convert 3d object to gcode
you can view demo video here for the milling https://youtu.be/iRbLDFfGRTc
Parameters Explanation:
Driller Size: this indicate the size of the cutting bit in mm, this used to configure the width of the paths
Moving speed: this to configure the GCode to move the head with mm/s speed
Driller speed: if your driller (spindle) uses TTL to control it’s speed -M command- this you could configure the driller to rotate at that speed (RPM).
For laser cut i’ll upload another video shortly
