Corel Draw - miss alignment
I use Croel Draw to design aligned circles and export the objects as *.svg.
When I import the file in Easel, the circles are mis-aligned.
Do anybody have a fix for this problem.
I’ve seen something similar with Estlcam and Inkscape. Try converting the circles to paths. That worked for me.
Thanks for your respond.
I have already vonverted circles to path = same problem with mis-alignment.
Other suggetions?
Several ways: Combine circles but will also be combined in Easel
Weld objects but same as combine, can’t apply diff cut types.
Create object around circles then when in easel, delete object.
One more way: Convert to outline. objects will stay in same position and be able to edit separately.
