Inventables Community Forum
Corner radius buttons?
does any one know what happened to the corner radius button that was under that shape tab?
As far as I know, it’s still there. Are you sure you don’t have the text selected, rather than the rectangle shape? When I just checked, I had the corner radius option.
Same here on my end.
Did you import the box with the text? Try creating another box in Easel and see if that works.
When you use the "create a box icon. Top left you get a box that has corner and center points on it. How did you create the box? if you used the drawing tool the option doesnt show for that.
1
i figured it out…i just closed easel and started it up again and it was there. i dont know what happened
