I suspect I’m missing something obvious, but I’m stumped.
I’ve made several projects which require a counterbored hole, or a recessed lip around a large hole. I can’t figure out how to do this in a single project in easel.
An example would be a 2.2" hole completely through a .75" piece, surrounded by a 2.4" diameter recessed lip. When I draw the lip I wind up erasing my through hole. My solution has been to make two projects which I cut one after the other on the same setup.
Is there an easier way to do this?
