Hi Folks,
I am making a Crank Organ, which has a face of 18w x 19L inches.
I Want to carve these in the corners one pattern upper right and left, and the other lower right and left.
I am having trouble as I use the app to bring in the image, which is 90 degrees on the corner - coming out not square on the import.
Also, I Want the corbels in the corners, but as a positive, not a cut out negative.
Please advise,
Thanks
Martin
I think I understand what you are trying to achieve. I will touch base with you tomorrow.
If you haven’t figured it out, we’ll get it sorted.
WOW!
Thank You!!!
I took a close look at your image and snapped some guides. It’s not perfectly square so that is adding to your difficulty.
yes
ss\o how do I open this?
THANK YOU! for your help
pm me your email address and I will send it to you.
