Create a PCD on a circle
Hi … I’m fairly new to Easel and slowly working my way around how things work , I have a project that requires some holes around a disc … I was curious to know if there is a simple way to set up a PCD of 6 holes … anyone tried this ?
Radial Array:
  • Open Easel, create an object (hole for instance)
  • Click to select this object and goto Easel/Apps/Radial Array
  • Select number, spacing and click okay.
Thank you for sharing this Haldor … I tried the hole option but that wouldn’t work , so I tried a small circle and yes after some trials I have that mastered … thanks again for your help
