I want to make a clock, how can i get the numbers evenly spaced around the circle i have created? Is there a app or generator for this in easel?
I always use inkscape for this, it
program to create 2D drawings. In inkscape you will find a star in the left bar and if you click on it you can indicate how many points your star/clock should have and that way you can put the numbers in place.
Bert
Thanks for the reply Bert, I figured out after i posted this that you can do an image trace off of free clock faces in google images. The numbers aren’t as crisp as i would like but will do for this project, again thanks for the reply and i will try your way also.
