I am attempting to input a custom bit size, .625. Whenever I attempt to put the size in, Easel is failing to recognize and update for the simulation. Is this a common problem or is it just my issue?
Thank you @PhilJohnson. I was trying to input the custom bit size after selecting the second bit. I guess you have to deleted the second bit, input the custom size, then choose a second bit. Must be a programming issue.
