I’ve read several threads about adding custom bits, and have used custom bits in my projects, but the customization is very limited when entering the bit and confusing when using the bit. it would be great to have pictures of custom bits that actually look like the bit we are adding. Even bits sold by Inventables don’t have appropriate pictures for the bits (ex. Surface bit). Multiple users have requested custom bits for cove, surface, keyhole, and varying degrees of V-bits. Thank you!
That would be a good question for the people at Investable. I have the same issue and I work around it. By putting in the name only also I put the info into a note pad for what works Bullnose is one of my issue.
