How do I cut out a 6” circle out of plywood. I have x-carve using easel. I am making corn hole boards and need the circle gone.
In Easel, click on “shapes” and then click the circle. Select the “Shape” tab and enter “6” in both the width and the height entries. Move back to the “cut” tab and select “cut inside shape path” and make sure the depth will cut all the way through the material you have selected.
This will cut your 6 inch hole. You can also use the rectangle from the shapes to define your rectangle for the Corn Hole game.
Oh my gosh. Thank you
