Keep getting this issue with the fill where when generating the carve file it comes up with an error under Cut Style - “Cut Depth is above Z Model” even though the file I want to carve is within the work area.
Just guessing but it appears you are not doing a 2 sided carve. You are set to " center of the material". I might see if changing that helps. For the record I’m not a Pro User.
your blank is too thick try .75 thickness or raise your model z to 1 inch your model z is ,75 above 0 with a full cut out ?
