Not sure why but cut depth goes much deeper than set to. I saw another post sort of the same. Are my settings correct? Thank you!
these settings look very similar to that of an X-Carve.
Is this for an X-Carve cnc? and if what is the year model and are there any upgrades installed?
A while ago I put this together that shows the defaults for the PRE-Nov 2021 version AND there are links to the settings for the upgraded X,Y and Z axises. (Note the changes for the “upgrade” are the same settings that a POST-Nov 2021 model will use)
