I have a project with 1/8 inch depth cut. When it starts to carve it plunges all the way through the wood. I used a z probe to set the z axis. Any help?
try setting the z axis manual with a piece of paper. instead of probe
Any chance the machine setup was done as the wrong version xcarve?
You can verify the settings are right or wrong specifically the $100, 101, and 102.
Here are the old xcarve settings, and there are links to the settings for the new version as well… called “upgraded”
Of they are wrong you can manually change them, or the easier method is to redo the machine setup and pick the right option… go to machine >setup new machine
