Cut Magnetic Sheets?
Anyone tried cutting Magnetic Sheets? What bit should I use? For something like this:
https://www.amazon.com/Corneria-Magnetic-Sheets-Adhesive-Magnet/dp/B003XNAHMC/ref=sr_1_4?ie=UTF8&qid=1507147132&sr=8-4&keywords=magnetic+sheets
Drag knife maybe?
I’ve seen someone cutting with ceramic bit. Cutting edge is no more than 3mm, but it is cutting super.
You can’t use any steel-carbide bits. Pieces sticks to bit. Just give name CNC Router Ceramic bit to google to see options.
(Only works for soft materials, not for others, even MDF)
Also check to see any info is suitable for you on this forum.
Thank you!
I dont think you will be able to cut that with a cnc router you might try a fiber laser or cnc punch press or possibly a drag knife
