I’ve used Easel before, but I’m coming back to it after a year and I’m having an issue. After I use image trace to import a drawing into Easel, it shows up on both the left and the right views. If I select the image, the Shape tab is active and I can resize the drawing but I am unable to set anything on the Cut menu because it is greyed out.
What am I doing wrong?
I shared the file that I am working on at
