Having a problem with cutterhead driving thru hold down clamps . mainly because the cutterhed drops to just above the workpiece at xy zero before moving to beginning of cut, and also only rises slightly when the cut is finished. seems like it would make more sense for the tool to move an inch above the workpiece before and after starting the cut. is there a way to modify settings to do this?
Go up to machine and general settings and you can change the saftey hight and origin height there.
That’s why I don’t use easel to run the design. Download and use ugs, it runs from home to work zero above the workpiece and then drops.
Really easy to setup and use
