I’ve been commissioned to make 36 signs out of 2 color King color core (black outside/ white inside) using a 2 flute bottom surfacing bit ( 1/8"). I’ve a few test cuts with simple designs using the recommended feeds n speeds through easel. When I cut I am getting alot of “fuzz” along the hatch fill tool path and ridiculous tooling spiral marks. I have a limited supply to test with and still get the job done. If anyone has had these problems and found a solution… please share… thanks
try a down cut bit
