I want to cut a radius in a project but can’t work out how too do it. I can draw a circle of the right size but its much bigger than the bed of my CNC. Is there a way of deleting the part of the circle that’s outside the bed or will Easel ignore it and only cut what’s on the work piece?
Easel will try to cut it and run into the sides.
Welcome to the forum David,
You will need to put a shape over the part that you don’t want to cut and set the depth to Zero
Thanks Russell, I’ll give that a try.
Worked perfectly, thanks mate.
You’re welcome mate
