Will my X-Carve cut Acrylic Plastic and if so what is the best bit for cutting it?
“0” flute would work best
Thank you for the information.
technically they are called o-flute (using the letter o) this could make a difference in the search results. . . and a more accurate description is single flute, upcut bit.
Thank you, I haven’t found them yet, but haven’t looked real hard. I will try your suggestion.
