Cutting not correct
Still learning to use my X-Carve.
When I cut letters or shapes, I get gaps see attached,
Any ideas?
sample_cut.htm (789.4 KB)
I’m not sure your file attached correctly. Can you try uploading a picture directly?
If there gaps, meaning areas not being cut, most likely the issue is you’re using too big of a bit and it can’t physically carve it. Switch to a smaller bit.
