so what your saying is it would be a two step process in easel. first pocket and maybe make one pass over the material, then fully carve it out?
I just made a quick edit to my post about time and bit diameter, in case you missed it.
You could do the pocket and outline it in a single project easily, it would just be a much larger pocket than usual. I’m assuming there would be some scrap areas along the perimeter where you could put your clamps, which would need to be outside of the pocket and outline area.
Hello,
The best way to cut your picture is by use of a laser. Now if you are scaling the picture up quite a bit then perhaps you could cut it out using a larger bit but even then you risk blowing out one of the thin walls.
Rocket League…Such a fun game… What are playing on…PS4 here
Thanks for the replies guys, I play on PC. I’m going to give it a try and see how it would turn out!
