Hey folks need help here.
Cutting out wooden signs and using a V bit (60) as my detail pass, however, is there an option to NOT cut out the frame with the detail pass?
Every time I try to cut out a framed sign using a V bit as a detail pass the same thing happens and I can’t seem to figure out how to change just the frame outline to use the roughing bit as the bit that cuts out the frame.
