I was doing a image trace on plexiglass and I could not figure out what was wrong I used a 1/8’’ upcut so it would pull the melted plastic up but as it was running the bit would get plastic stuck on it and it would not cut as well and I would have to pause it and clean the bit does anyone have a suggestions
search for acrylic on this forum. there are plenty of threads about it
Single flute. Spindle speed slow. Shallow cut. Move it very fast so the plastic doesn’t melt.
Ya, if it’s ‘melting’ you are going to slow. You want ‘chips’ flying out.
Robert is 100% right with this - they cut completely different. Plus the other suggestions, those are good too
Ive been cutting a bunch of cast acrylic. I used the 1 flute, carbide, upcut.
65 in/min
Spindle speed 1
DOC - .006
Use the exhaust port of my shop vac to blow chips away.
Get really nice results.
I have a two flute 1/8" upcut should I go two times as fast as a one flute
Each machine is slightly different. go up in increments. Once it chatters, pull back. try 75IPM. Also - if the ‘plexiglas’ you bought has a plastic protective cover, it’s extruded. Cast will have a paper cover.
What do you mean by shatters
You’ll know when it chatters.
I was having some difficulty cutting extruded Plexiglas and damaged 3 cutters in the process. Based on suggestions made by previous posters I used 2000mm/min for the profile speed. Makita spindle speed position 3 (whatever the rpm is) and depth of cut 0.2mm (.008"). Two flute up cutter 1/4" dia. It took a while, 50 circuits to cut 10 mm thk material. Continuous Vacuuming of the profile. Came up with an acceptable finish, and no clumping of molten acrylic. Would probably do even better with a higher feed … 2500 - 3000 mm/min perhaps.
