I wan to cut raised letters on a cut out circle. Who can advise me.
Create one circle set to outline outside, full depth. This will cut out your circle.
Create another circle set to fill, the depth that you want the text to be raised. This will give you depth to “raise” the letters from.
Create the text, set to zero depth (or a depth that’s less than the fill circle). This will give you letters that are higher than the background.
