Hi this is the first time this has ever happened. But when I setup a file in Easel, copy it to a usb thumb drive then put it onto my pc running the CNC USB Controller. And for whatever reason it is carving a lot smaller than it is supposed to. Not sure why
Microstep mismatch AND/OR incorrect step/mm values for X/Y/Z.
I thought so too. But it shows up on cnc usb controller software smaller than it is supposed to be. As an example my bed is a 6090 and it shows on my screen that way yet when I import a file it shows up much smaller on the screen that it should be.
Just a thought but could you have one set to mm and the other to inches?
Nope. I thought of that as well.
How big is it supposed to be?
Share the gcode and Easel project here.
