Dead Spindle
Last night all was fine, woke up this morning to start a project and the spindle is not working :frowning: ugggg What’s going on with these spindles? Guess i’ll be hitting up help@inventables instead of cncing today
Is it exhibiting the behavior of not starting up unless you manually spin it slightly? If you usually use it in logic mode, does it come on when you flip the switch to on? Is it possible you have a loose connection?
won’t start in logic won’t start when switched to on, there sending a replacement
