Hi.
How can I cut deeper by using multiple passes with same bit?
Is it a case of adding multiple bits of the same type and increasing the cut depth on each one?
Or is there a simpler way?
Cheers!
Andy
Under cut settings, Depth per pass
When you define the total depth you’d like for a cut, you then specify the ‘depth per pass’ as Steve pointed out. The bit will then carve out the total depth you specified making each pass at the ‘per pass’ setting.
For example: If you want to carve 1" inch deep using a setting of .25" depth per pass. It will take 4 carving passes to reach the bottom.
Ah Cheers, so I don’t have to specify number of passes, as it’s done automatically based on total depth of cut.
Thanks for that peeps.
Clear now.
Andy.
