Any one having belt issues with new machine builds? New machine out of the box. went to tighten the belts, and With very little tension (SNAP) and i do mean very little! Possibly defective? well so close to finished and this happens.
sound like to tight. old belt, I an using metal rigid track and spring tentioning.on my next project, no belts on any of it.
Well that would be true. but i had placed the bolt in the bracket and stretched it to install the nut and snap. Maybe Old Belt.
having spent my youth on an assembly line I have seen a lot of “new” parts that are shot. They set on a shelf to long or fell behind the parts bin.
For a machine I got from another source, I had a premature belt failure, so replaced belts and pulleys with 9mm wide ones from SDP/SI — they seem to be much better quality and “grippier”.
- Product | Designatronics Store | Stock Drive Products/Sterling Instrument
- http://www.sdp-si.com/eStore/Catalog/PartNumber/A%206A51-020DF0908
I really wish all the vendors would note sources for parts and provide a list of alternates — tried to do that on the Shapeoko wiki: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable and would welcome additional sources of documented provenance.
