Deflection causing notches in outline carves
Developed a line cut on outside edge of tabbed thru cuts. This is showing on both top and bottom of cut on the outside edge when bit goes up and down for tabs. Also have a slight offset cut when bit changes depth of cut as seen on lower center of circle pockets.
Any ideas as to what I might check? Have already checked wheels and belts.
