How can I remove one side of a rectangle in Easel?
The part I have to cut out is a strange piece 12" wide and the material is 12" wide. I cannot hold it down on one side. But regardless, is there an App to convert a closed object into individual paths? I thought there is, I just did not find it (?)
Thank you in advance.
I think it is impossible. A closed object has an inside and outside, so it make sense to cut inside or outside. Once you make it lines, it can only cut on the line. Not good
you can use the line tool and make a line with the desired shape… OR place a 0 depth rectangle on top of that side you want to not cut.
Ahhh… You are golden. I am using the line tool, but you have to adjust the location as it cuts ON the line. Adding/subtracting half the drill diameter. BUT covering with a rectangle works, that way I don’t have to modify/delete the original shape.
Thanks Seth!!!
