Having a strange issue. I have an X-Carve with the X-Controller. Have been using it a couple of years but have always used Fusion 360 and CNCjs. Needed to cut a half a dozen holes in some MDF so Easel seems like it would be faster/easier, but holes were only half their depth.
Simple Test: Go into CNCjs, home machine lower Z 10mm and bit moves 10mm. Go into Easel, home machine lower Z 10mm and bit moves 5mm. Research says maybe $102 is wrong. I have upgraded the Z and use a different lead screw. I don’t remember what settings I changed but I turned the Z when I changed the Z-Axis and all works fine in CNCjs.
How can one be correct and the other be wrong? Does CNCjs use different command(s) that don’t use $102? My concern is if I change $102 to make easel work, then CNCjs will now go twice as deep as intended.
Thanks
