I is there an easy way to draw rounded corners on boxes? i cant seem to find anything in the software
If by “the software” you mean Easel, and “boxes” means shapes with right angles, then use Corner Radius on the shape tab.
That was what i was looking for thank you very much for your help!
Is the radius corners option only available on easel pro? I do not see it, that window stops at “rotation” ?..
Thanks in advance
