My design is only partially carving. I’m using a 60 V carve but still doesn’t carve the finer lines??
can you share the easel project and your carve result if you ran the carve already?
Go to Project>Share> change to unlisted> copy the link & paste it over here
Hi Seth,
I’m not in my shop but I’ll get that out to you ASAP.
Thanks
Wayne Dean
Select the entire design, in the settings popup select the “cut” tab and then at the bottom change it from “cut inside the path” to “clear out a pocket” . . .
Final step: Have fun carving
