Hi guys, just wanted to share me latest x-carve cut. Made it for my wife’s desk.
Designed in Fusion360 (i can share files if you want). I used 1" pinewood laminate, feed 1700mm/m, depth 3mm, rpm 2.5 on dwp611.
Hope you like it!
Hope you like it!
That look great.
You designed this in Fusion360? Or you just set up the CAM gcode in Fusion?
I would love to know the process you used for the curved “dish” I’m wanting to do that for another project. Great work!
@BrianRizzo hey brian, for the dish, i just created a sphere and used a cut combine op. As for the CAM part, i used 3D Pocket for roughing with 0.5mm stock leave and then used 3D Scallop with 0.5mm passes for finishing (i had to sand a bit, which is quicker than running very small cleanup passes for wood).
Great work. Fresh and modern.
I use Fusion360 too, it’s very good.
@AndrewGemmell thanks! I really like fusion, i work with Maya every day and being totally different software i feel right at home with it.
I would love the files for this desk organizer if you still have them! (Note: I know this is an old thread, just hoping the OP is still around!)
Hi Elizabeth, I’ll try to upload the fusion files tomorrow if I have e some time!
Hi! I would be interested by the files as well.
I’m looking to lean CAM + Fusion on our shopbot.
Cheers
Hi Guys! I totally forgot about this, been busy lol. Ill try and share the fusion files this evening when i get back home.
