Have you tried replacing the brushes? They will last 150-200 hours of run time with the router speed on 1.
You could get a Makita router to fit in the Dewalt mount but you will need a shim because the Makita is 65mm and the Dewalt is 68mm.
Or you could upgrade to a CNC4Newbies Z axis and order a 65mm mount. I upgraded everything on my XCarve from CNC4Newbies and everything works great. A few people that use this forum upgraded their Z axis from CNC4Newbies and they have said good things about it. @PhillipLunsford is one and @SteveMoloney is another.
Check out this old thread about the Makita router and using a shim
