@clyde can you post a pic of your machine? im thinking about a similar setup with mach3
Sorry-I can’t answer that on account that I got about five flags for being of topic.
id be happy for a new topic with pics of your awesome machine… that way no flags!
Excuse me, Only FOUR flags for being off topic.
Someday.
In the darkness, he waits…
to the one flagging these post on my thread
Anyone in Canada have any luck sourcing the replacement brushes locally?
Really struggling to get the brushes in Canada
I think these routers are not intended to be CNC spindles. They are designed for using a few minutes at time for small routing projects, and not used hours at a time spinning. My brushes just wore down after 6 months of light use. I have cut some large projects though that took several hours to cut. If these are continues to be used, I guess I am going to keep a set of brushes on spare.
It is going to take up to 10 days to get new brushes from Amazon. I decided to make my own brushes though. I found a local store that sold graphite rods. I bout a 12 inch, 1/2 inch diameter rod, and used my Dremel to grind a few inches down to the same size as the brushes. I recycled the connectors from the old brushes and drill a small hole in my homemade brushes, and used Gorilla Glue to hold it all together. I am letting it dry overnight. I will post the results later.
Homemade brushes work great! after about 1 minute of spinning, it quit sparking and started running very smoothly.
Hello. I have the 240v UK version of the dewalt 611 router. Can I put the same brushes being sold in Amazon to my unit? Thanks.
Not saying they use the same brush but i have only ever seen one part number
The motor itself is DC, AC input dont affect the brushes.
Looking into this myself at the moment - the part number for those brushes (the Amazon ones) lists them as BRUSH 120V
There is another part number that’s just BRUSH - so I think those maybe the UK / EU version, rather than the 120V ones?
Basing it off this - DeWalt Genuine Spare Parts D26200K Compact Router - Type 1 | eBay
I’ve just sent a message to the ebay vendor to check which brushes we need for the UK version - will update when I get a response
Response:
Hi there,
you will need A28459 x 2 theses are UK parts Dewalt just have a weird part number on them.
Kind regards Jamie
Power Tool Centre Ltd.
Which are the ones labelled BRUSH in the ebay link above - the Amazon.com ones are the US version BRUSH 120V
Thanks to all of your replies.
