So, I know the answer is going to vary depending on what your are cutting, mainly I will be cutting alot of maple, alder, rosewood, mahogany with my xcarve 1000x1000 with the dewalt 611 router, any helpful suggestions on the speed settings on the router i should use? also maybe some feed rate suggestions please? thanks!
Wow! And I thought that I should use it at 4 minimum . Thank you!
