There should not be a lot of black carbon inside. If you are seeing any then the brushes are rubbing to hard against the commutator… This could be due to badly adjusted brush neutral setting, interpole strength, low brush spring pressure or poor brush seating.
If it is still under warranty I would just swap it out.
