As may be noted by my many questions on these boards, I have had a number of issues. I have yet to get a repeatable (or even any) carve from my machine, but, for whatever reason, I have not given up hope. I finally took a bunch of my machine apart (original 1000x1000 x-carve), tweaked nuts, loc-tited the crap out of everything, did all kind of tests and runs to really dial in my pots, etc., etc., etc. Let’s just say that the mechanical parts have been fine-tuned to death. (Apparently my death, moreso than the x-carve, but I digress).
In putting the top back on my power supply after tweaking the pots a second time, I inadvertently pulled out two wires on the Y-controller on the g-shield, so I patiently got those little buggers back in and went to turn everything on to start some tests on some wood now that everything was ready. And the universe laughs.
No. Of course not. Now my USB cable will not communicate with the power supply. It would appear by this photo that the Arduino is getting power from the computer, so one would think that the USB cable is working.
However, the first thing that I noticed was that I didn’t get the Windows 10 chime when I plugged in the USB cable. Nor did I get the disconnect chime when I unplugged it to try it in a different USB port on my computer. Prior to today, I would always get the notification chimes from my computer that it had, indeed, found something connected via USB.
Here is what I have tried:
- Replaced the cable
- Tried a different USB item in the port on the computer to make sure that the port on the computer hadn’t gone bad
- Rebooted the computer (someone was going to ask that, I’m sure)
- Installed the Arduino update
- Installed the Easel update
- Tried to go through the machine installation within Easel (but it cannot find anything since it doesn’t seem to recognize the USB device)
I am wondering if I fried something - either an entire card (Arduino or g-shield) or I have somehow broken the USB connector at the Ardunio board. I have read some people on the board who have suggested a powered USB connection, but I didn’t have one of those before, so while that might be an addition down the line, it wouldn’t be the cause of it not working now.
Let me just say that I know nothing about sending commands to the Arduino/g-shield; I have only been using Easel to communicate with the system, so if you ask me to try something that requires sending code directly to the system, you’ll have to give me baby steps.
If I DID fry something, I guess I should bite the bullet and get the upgrade kit. Which, since I just spent DAYS dialing in my nuts and bolts and voltages will just make me even more BITTER AND ANNOYED than I already am (and that’s saying a lot).
I know I’m verbose. Let me know if there’s something that I didn’t say that would be helpful.
