Different wood to whats in easel
i want to use pine what wood settings should i use please and thank you
Make sure your bit is sharp too. A dull bit and pine don’t make fur good results
thanks for the info
:grin:I see what you did there!
so job depending I would use a solid carbide downcut 2-flute bit for best results .25" in diameter and around .125" DOC and around 100 ipm
but I would run some tests and see what surface finish you achieve
