Hi, Im very new to Easel so Im learning. I want to start out in a different position than the zero axis. Can someone please explain how to do this. Thank you.
You can change your home position when you’re setting up your carve. Do you have an example of what you’re trying to do?
Thanks
Russell
Easel zero point is always in its XY0 position.
You can place your design with the lower left corner at XY0, or move the design around, for instance center the design over XY0.
