I am new to easel so any help is appreiceated. If I want to make a square that is 2" x2" is there a dimension tool to resize it after it’s drawen
Hey Jordan…
If you click on the shape… and click on the “shape” tab… you can you use the size for width and height… in this case 2" x 2"…
Have fun…
Just select your model and then adjust the dimensions using size in the cut/ shape tab. Select the lock to maintain dimensional relationship.
Thanks for the fast response
