Disregard Bit Size
Title may not be appropriate so I’ll explain. Several times when using an 1/8" bit you commonly run into thin spots on text or in a design that the program realizes are to small for the current but diameter.
I often would like the ability to disable this and allow it to make a pass to complete the design. My thought is that it currently sees a path that would be to narrow let’s say less than 1/8" so instead of not creating a path it would create a single path rounding up to the size of the but in this case 1/8".
Is this possible of useful to anyone else?
That’s a coincidence! I just posted about the issue here:
I haven’t tried cutting this project yet, but I hope it will cut regardless of the warning.
When this happens with a “fill” shape, I’ve had pretty good luck copy/pasting the same shape directly on top of it and using that one as and inside “outline” cut.
just hide the material and all that red stuff goes away
You can also change to it to On Path.
In my case that’s not really an option since that would produce different result then I want.
pretty sure it will still cut since the toolpath is shown
Just got a reply from @rodovich of the Inventable teams this is what he said:
http://easel.inventables.com/projects/fXUgH2XbDhC2zvabndHAJA
maybe try something like this?
