I’m trying to make a box using the box app. the app adjusts for changes in size, but I want to use .25" material and it is set for .5". The design does not change as you change the material from .5 to .25 material. I have spent the last hour editing the design for .25" material only to end up with the final piece, the bottom, and it has dogbone corners I need to move. How do I do that? I see how to add dogboes, but can you take them away, edit and readd?
Build a vertical table into your machine, It comes in handy for all sorts of joinery, & you no longer have to put up with “dogbones”
Firstly, if you choose the material prior to importing the box app, the app actually does adjust everything for that material. (only 4 hours of editing down the drain!) What is a verticle table?
BTW, thanks for getting back to me, Anthony!
@WilliamJohnWalker If you goggle woodworking CNC vertical table you will see all sorts of variations. I always knew it would be needed so designed and built mine. Actually used my first spoilboard, cut it to the size needed for vertical, fixed it in place & never looked back. Only use it once in a while but it is amazing what you can do with one.
