Doing multiple cuts
Can you complete one cut and the go back and re cut just select letters without carving the whole thing again?
Sure you can. I have done multiple cuts (sometimes to add a bit more depth), and it does work… for the most part.
Thank you!
You may have already figured this out, but if not, just change the depth setting of anything that you DO NOT want to carve to 00.00" depth, and it will not attempt to carve that part of the image.
