Don't add depth to copied hole
I needed to drill a lot of holes in a game board so I copied the previous hole and it would add a little to the x which is fine so they are not on top of each other. But it would add to the depth of cut which there is no reason
Can you tell me exactly what the depths were before and after the copy operation? Was the new object a different depth, or did both change?
Sorry I haven’t gotten back to you sooner but I was putting together the machine and I got a bad PSI board.
My plan on easel was a lot of holes .33 inches deep I would copy the whole and paste it it would add a little to the x axis so the hole wasn’t on top of the other, that was fine I was moving it anyway but it would add .0024 to the depth so it would be .3324 but if I copied the .3324 hole it didn’t add any more.
