good afternoon to all
I’ve been milling all day. I stop to change the bit, try to restart and when I run the procedure
raise the cutter
switch on the spindle
it doesn’t work… I don’t know what to do and above all I don’t know why.
help meee
Can you explain a little better. Maybe you are trying to carve something with to big of a bit. If you run the simulation does it show you have something to carve?
i finish my last work. change project when i start with carve don’t move. machine in allarm.
easel tell me ALARM2 in the inspector
I am not the best guy to talk to about the alarm2 but i think it might have something to do with the soft limits. Maybe try rehoming and see what happens.
ALARM:2 : G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked.
Your machine is told to go somewhere outside its defined soft limits. Check design for overall size and/or offending parts outside intended scope.
