I need another drag chain that runs parallel with the Y axis for the 1000mm XCarve, I want one that is similar to what comes with the XCarve, can someone let me know if this one will work or if you know of one that I can use. I want the tabs to be able to open.
Thanks
Russell
https://www.amazon.com/LMioEtool-Plastic-Carrier-Length-Connectors/dp/B07QZR6BW1/ref=sr_1_1_sspa?dchild=1&keywords=openable%2Bdrag%2Bchain&qid=1603566984&s=industrial&sr=1-1-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUE0WUNKVjNGRTlCTkMmZW5jcnlwdGVkSWQ9QTA4MDU2MDQxV0xYS1JEM1AyNVE3JmVuY3J5cHRlZEFkSWQ9QTA1NDcyNDYzQVowTVVMSDFLVFRNJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1
Well that one does open and kind of looks like the one I bought. I found the holes in the ends didn’t match up with the X carve one but that wasn’t a problem as I only used one of the two holes and screwed it to my wasteboard.
Thanks Martin
